4 PCB colors ... which is best ????
A project log for IV-3, IV-6 VFD 6 digit clock Shield for Arduino
Redesigned AXIRIS IV-3 Shield with DS3231. Battery and buttons ... + 2 Extra Digits
bobriciusbobricius 03/12/2020 at 21:305 Comments
TomasOlah wrote 02/08/2026 at 09:55 point
Yellow PCB is the most retro.
Ian Shannon Weber wrote 03/14/2020 at 05:04 point
If you are going for aesthetics, then you matching colors for all your boards might be the way to go. However, if they differ in tone, it will be very obvious and I promote using different, but complimentary colors.
On a technical aspect, green and yellow tend to be very distinct and allow you to spot traces better. So if you messed something up it is easier to bodge together a fix on a green or yellow board.
On a personal aspect, I am a sucker for red. I want red pcbs when I am not worried about time.
danjovic wrote 03/13/2020 at 20:18 point
Yellow suits tube technology better (aesthetically speaking)
Marcel van Kervinck wrote 03/12/2020 at 23:09 point
The one that matches the Arduino
deʃhipu wrote 03/12/2020 at 22:00 point
Yellow, of course, but I prefer it with black silkscreen.
