Here is a prototype of the wire bending & spotwelding toolhead.
The toolhead consists of a copper electrode in the center and a wire feeder which can rotate around the electrode to bend the wire in the moving direction.
There are still a few things to figure out:
- Using this kind of toolhead the machine will later have 5 axis (X, Y, Z, E and rotation) which requires software and firmware which supports it.
- The rotation axis needs an endstop, too. Maybe I could use a hall-effect sensor on the top plate and a magnet on the gear. Will test that the next days.
- There could be a problem with the bowden tube colliding with the gantry system.
- The wire is directed at the electrode, but if the electrode misses the wire the print can fail. Maybe a greater diameter electrode could help, but it could also increase the distance of two wires next to each other.
I addad a hall sensor to the toolhead to act as an endstop.
- Ordered a ∅6mm copper rod for using it as electrode, so that it's more likely that it will hit the wire.
The next step will be building the frame and finding a way in which the PTFE tube can move without colliding with the rest of the spot welder.
