Added the component list (Read this if you want to replace some of them)!
A project log for Active electronic load
This project contains all needed files (hard- and software) to build an accurate and fast electronic load with hobbyist friendly components.
abaumgartnera_baumgartner 02/19/2020 at 10:470 Comments
I've added the components of the bill of materials (BOM) to the project.
These components are what I have used to build this, of course you can change most of them to other values.
When using other operational amplifiers, be aware to choose components that are suited for this usage and that the pinout and the functionality might is different.
The following specs should be handled with care:
Other things that can be changed:
Enough for now,
if you have any questions about the project or want to know something specific, feel free to ask :)!
Rich text editor
