Open Source Hardware
Eagle project files are available in the "Files" section of this project.
The Bill of Materials is maintained in this project log.
Background
The original BASTARD circuit used no feedback at all, ran on very low voltage and the gain was controlled by the power voltage. Several people collaborated on the Danish forum HIFI4ALL, made measurements and came up with a modified version that has feedback, much lower distortion values, higher power voltage and a set gain of 2.2X: http://www.hifi4all.dk/forum/forum_posts.asp?TID=59789&KW=bastard
This preamp was called the Bastard because it was a three-part hybrid:
- A transistor phono stage
- A valve line stage
- An input selector with relays
As this project uses only the line stage it's no longer technically a "bastard". I decided to call it the BSTRD as a nod to the original design.
Vital specs
- Input voltages: ~80V DC/0.1A, 6V DC/1.5A (Power supply info here: https://hackaday.io/project/16944-the-muffsy-bstrd-valve-preamp/log/49425-power-supply-updated)
- Valves: 6J5 or equivalent
- Gain: 2.2X / 6.85 dB
- Frequency range +0/-3 dB: 10 Hz to 30 kHz *)
- THD at 1V out: 0.35% *)
- SNR at 1V out: 93.2 dB (A-weighted), 83.5 dB (non A-weighted) *)
- Circuit clips at: 17V rms
*) Measured using Russian 6S2S tubes: https://hackaday.io/project/16944-the-muffsy-bstrd-valve-preamp/log/50558-the-bstrd-measurements
Sagar 001
alcor6502
Yann Guidon / YGDES
Hi, there is an error in the mouser shopping cart as well as in the component list.
Screw Terminal 651-1705469 is 2 pole type, should be a 3 pole type 651-1705472.
Is the mix between MKDS and SMKDS intentional?
