Today's tasks:
- Configure DAC: make sawtooth wave
- Configure op Amp as c2v converter
- Choose GPIO and output 100 Hz and 158 Hz square waves
- Start designing IR receiver circuit
Configuring the DAC wasn't hard, but with the Curiosity board there's a gotcha. Pin RA0 (DAC1 output) has some kind of load (edit: an LED is attached) on it. The DAC is simply ramping up/down using the DAC1CON1 register. With several tries I only reached 2.0 volts at peak (you can see in column B).
Eventually I pulled just that pin out of the socket and this is the nice signal, exactly as expected.
