taps and drill arrived from drillsandcutters.com and transfer punches from harbor freight. The y scale ia almost fitted. I need to make end brackets that will do:
- Space out the scale to line up with the head
- Close the ends of the cover
- Provide something to screw the cover to
The cover is 16mm longer than the scale and comes with a vertical lip to allow you to screw it to a flat surface. I bent/hammered that lip flat as the top of the cover will be flush with the table. This also makes it wide enough to reach out over the head bracket.
![](https://cdn.hackaday.io/images/7964111584426929440.jpg)
