Coding Coding!
04/26/2020 at 06:53 • 0 commentsServo amp control library coding!
Modbus test
04/15/2020 at 03:15 • 0 commentsRS485 modbus servo motor control via arduino test...
update preview
04/07/2020 at 20:33 • 0 commentsI've made a breakthrough on how to drive the servo motor and are preparing for a test drive.
And there is an update on some CAD model modifications.
hard working!
base modify
03/26/2020 at 03:50 • 0 commentsAs I was modeling, I felt that the bottom post was too small, so I'm reassembling the floor.
NEED 4 VRAM
03/21/2020 at 20:34 • 0 commentsI need more VRAM!!
fusion360 getting slow!
AC Servo buying for test
03/20/2020 at 00:57 • 0 comments2020.3.20 // AC Servo buying for test update.
As I was modeling, I was trying to figure out which motor would fit my robot, and I decided that AC servo motors were suitable, and I found a servo motor store in 'Aliexpress', a Chinese shopping mall that was generally good to find.
The motors that will be used in joints 1, 2 and 3 in earnest are much higher power than the ones I've purchased now, but I still don't know how this servo motor driver works, so I bought the cheapest motor to practice.
The company's AC servo motor driver products are A4 and B2. They say A4 is an upgraded version than B2. When I asked the person in charge by e-mail, they said the five biggest differences are like thisA4 is a new driver, it with more function then B2, bellow is the function which added on A4 based on B2 driver
1. Support pulse + direction, CW / CCW, AB pulse three pulse modes;
2.Support pulse feedback frequency division function;
3. Support ± 10V analog voltage;
4. Support origin search function;
5. Add 24V pulse input common terminal and 24V collector output Z signal;
6, support MODBUS bus control;So..the options that seem useful to me are number 4 and 6. First of all, A4 driver is an upgrade version of B2 driver, so I think B2 driver will support basic functions. So I bought it with the A4 servo motor driver.
That's what's troubling me right now. No A4 driver can control more than 2.6 kw of power! So I have to choose between A4 and B2 driver. If this motor that I purchased as a test can do as much as I want with the A4 feature, I will buy a B2 driver.
But I'm worried because A4 driver supports a serial communication called MODBUS. If I don't use serial communications, I'll have to build another hardware to connect the uC to the servo motor control wire.
Model name LCMT-02L02ZB-60M00630B Brand Lichuan Frame size 60mm*60mm Motor langth 164mm(with brake) Shaft Dim 14mm Driving V(AC) Single/3phase 220v Rated torque 0.637N/m Rated speed 3000 RPM Position Accuracy wire(0.01mm) Encoder Tamagawa 2500ppr Weight 1.11kg Driver Lichuan 200w servo driver Annnnnnnnnnd
that motor has include internal brake resistor behind the controller.
and electronic brake too.(for emergency situation.)
PRICE!!! : 248.54$+(41.57$ shipping)
expensive...:(
Day update
03/16/2020 at 20:14 • 0 comments2020.3.17 // day update. Base comp
so tired..
Why is the bearing so expensive? almost 400$!!! omg..
from. South korea
Base_joint1_base shape teaser
03/15/2020 at 11:40 • 0 commentsHard working!
Base comp assmble ver.1
03/14/2020 at 06:04 • 0 commentsIt's moving!
comp arrive
03/14/2020 at 04:28 • 0 commentscomp arrive
