Introduction
A project log for PiBox
Just a conversion from an empty drill bit case to a Raspberry Pi laptop by laser cutting some inserts and plugging things together.
rich-maynardRich Maynard • 01/24/2020 at 10:49•0 Comments
I had an unused drill bit case and a Raspberry Pi, so put them together with some other components to make a laptop aimed at makers.
I looked around for a supplier of the drill bit case without the drills, but can't find one. You can get the case and 99 drill for less than a tenner on eBay anyway.
https://www.ebay.co.uk/itm/Titanium-Coated-HSS-Drill-Bit-Set-99-Pcs-Piece-and-Case-Wood-Metal-Kit-1-5-10mm/164038303500
