There are a few changes that need making to the arrangement of parts:
- Jumper wires need to be longer to provide power to the Pi from the screen
- Jumper wires need to be longer so touchscreen can work over SPI
- Battery needs to move to right so power supply cable actually fits in around screen (component box could then be a bit bigger)
- Component box doesn't line up properly with its lid
- Would be nice if it were a little easier to remove component box
- Paint it, or maybe use some veneered MDF instead
