Another 14 month gap between filter changes & once again a light vacuuming instead of a complete rebuild. The dust is definitely building up on the inlets since those require a rebuild.
Added more foam bits to space the inlet. The light vacuuming process takes 1 hour, compared to many hours for a complete rebuild.
The filter change made a meaningful difference in air flow, this year.
Weather stripping installed in 2025 concentrated more of the airflow in the inlets. Those had a lot more dust than 2025.
lion mclionhead
