Hi, so I wanted to update you on the Code Editor.
I’ve got a working Code Editor, which by brother Nathan ‘made look nice’(styled it with css) but it is now officially discontinued.
Basically, I haven’t done it for ages and I can’t work out how to do syntax highlighting.
This is still on github, so you can go and check it out from there!
