- Dimension: 2.56 x 2.56 Inch (65 x 65 mm)
- Several boards can be tiled together, maintaining the LED pitch.
- Each pixel is individually addressable.
- Supply Voltage 3.7 to 5.3V
- PCB Thickness: 1.6mm
- Surface Finish: LeadFree HASL-RoHS
- Intelligent reverse connect protection
- Contains a constant-current driver cooked right into the LED package
- The color of the light were highly consistent, cost-effective
- Daisy chain able
- Only one microcontroller pin is required to control all the LEDs, and you get 24 bit color for each LED
Typical Connection
Hugo
Voja Antonic
Mirko
Tinkers Projects
Tokoro
