Whilst the project is based on the X60, there is no reason to not try to take full advantage of the status leds and thinklight to their potential / have some fun, rather than try to reconfigure the existing leds in the top panel. Previously these were handled by the display backlight board which there were status leds for bluetooth, wifi etc. As a new display will be fitted without a CCFL backlight a different configuration can be designed on a small custom board.
Dependent on how things go I will likely add a microcontroller to ensure full control of all indicators to potentially add more, or make it rgb or even replace it with a small LCD or OLED display.
For those looking to upgrade one of the original CCFL based LCD panels shoud go to:
https://people.xiph.org/~xiphmont/thinkpad/led-backlight.shtml
xiphmont has documented multiple methods and products and is the best place to get information on the led backlight conversion.
