Hackaday.io Hackaday.io
Sign up Log in
EchoDe : Amazon Echo Controlled Appliances
ESP8266 12E based hardware running Sinric firmware, enables Amazon Alexa to control appliances
aditya-mukherjeeAditya Mukherjee
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
3 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
277
0
3
0
Team (1)
  • aditya-mukherjeeAditya Mukherjee
Join this project's team
  • Github LInk
completed project
hardware
Alexa amazon Echo smart iot appliance home automation smart appliance ESP8266 Relay switch voice control voice activated ai ML sinric pcb soldering
This project was created on 01/29/2020 and last updated 6 years ago.
Description
ESP8266 12E powered hardware with two relay outputs for connecting appliances. The appliances can be powered either by the Vin (DC) voltage source or an isolated external voltage source which can handle mains voltage. So, both low voltage and mains voltage appliances can be controlled using this device.
For this to work, the device needs to be connected to the same WiFi as that of the Amazon Alexa device.
After a little configuration in the alexa app and setting the correct WiFi name and password in the hardware, controlling an appliance is as simple as saying "Alexa switch on "
Serial pins and other ESP8266 pins are made accessible for reprogramming the device and adding peripheral functions.
Details
Components
  • 1 × ESP8266
  • 1 × Amazon Alexa
  • 2 × Relay Power Supplies / Uninterruptible Power Supplies (UPS)
  • 2 × LED Strips
Log In/Sign up to comment
Sign up with Github
OR
A device to enable more fun and experiments in circuit analysis
Project Owner Contributor
The GearsNGenes ADS1115 FeatherWing
gearsngenesgearsNgenes
AC Dimmer is designed to control the alternating current voltage, which can transfer current up to 600V/16А.
AC Dimmer
mbsg99mbsg99
High-Voltage Serial UPDI Programmer for tinyAVR Microcontrollers
CH340 HV SerialUPDI Programmer
stefan-wagnerStefan Wagner
There are mainly two types of Transistor they are NPN type of transistor and PNP type of transistor
2N3584 NPN Transistors
engineerkid1engineerkid1
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "EchoDe : Amazon Echo Controlled Appliances", please tell us the reason.
Send message
Remove Member
