Just:In.Time
images brought to light through time
An LED strip on a linear axis that displays images that can be captured with a 15 second camera exposure.
Real time video of the "woman yelling at cat" image:
Pictures of the internal assembly:
just_in_time.ino
The Just:In.Time Arduino script that reads the pixel information that was generated by the Python script and commands the linear axis and LED strip.
ino - 287.41 kB - 02/22/2020 at 20:57
Download
get_led_pixel_data.py
Python script to extract pixel information and format it as an array that the Arduino script will read.
py - 1.83 kB - 02/22/2020 at 20:57
Download
just_in_time.STEP
3D model of Just:In.Time assembly
step - 5.40 MB - 02/22/2020 at 17:54
Download
just_in_time_laser_cut_sheet2.DXF
12x24in, laser cut template sheet 2
AutoCAD DXF - 97.67 kB - 02/22/2020 at 17:51
Download
just_in_time_laser_cut_sheet1.DXF
12x24in, laser cut template sheet 1
AutoCAD DXF - 109.42 kB - 02/22/2020 at 17:51
Download
  • 1 × Arduino Nano
  • 1 × TMC2208 Stepper Motor Driver With Stealth Chop
  • 1 × DC to DC converter, 12 VDC to 5 VDC 3A 15W
  • 1 × Metal Momentary Push Button Switch, 12 mm Dia Panel Mount
  • 1 × SK6812 RGBW LED strip, 144 LED/m, 1m, White PCB
View all 17 components
  • Lessons Learned
    John Opsahl • 03/01/2020 at 17:02 • 0 comments
    The stealth chop stepper motor driver and addressable RGB LEDs were technologies of this project that I had never worked with before. I was really impressed by how silent the stepper motor ran using the stealth chop driver. In fact, the only noise during operation is the rubbing between the linear axis cable rail and and the enclosure wall; something that can be avoided by making the enclosure a little wider. The addressable LEDs were just ridiculously fun to control with an Arduino. I also enjoyed learning about LED gamma correction that is used to achieve better human perceptible color contrast.
    The only things I would change if I was going to build this again are the 12V power supply AC wire routing and the mechanical connection between the LED strip cart and linear axis. At the moment the AC wires are routed directly over the Arduino Nano micro controller and stepper motor driver. I am a little surprised that this hasn't caused any signal noise issues. My best guess is that the AC currents are low enough to not be an issue. Also, with the current design it is not possible to move the LED strip across the full length of the linear axis in less than 15 seconds without significant oscillation of the LED strip. Stiffening the mechanical connection between the LED strip cart and the linear axis will reduce oscillations at higher speeds. Ideally, the LED strip would move across in less than 10 seconds to be more in line with the camera exposure capabilities of most smart phones.
View project log
Ahron Wayne wrote 06/26/2020 at 01:53 • point
This is really cool. Have you considered getting higher horizontal resolution by taking smaller steps and changing your brightness? I mean, I *think* this is possible :-)
John Opsahl wrote 06/26/2020 at 17:47 • point
Thanks Ahron. The resolution is currently limited by the maximum speed that the linear axis can move without oscillating the LED strip and the longest shutter speed of my digital camera. 15 seconds is my camera's longest configurable shutter speed. So the linear axis has to move fast enough to complete the entire image in that 15 second window. At 72x72 in 15 seconds, the LED strip is right on the edge. Any faster and it will likely oscillate and distort the image. A longer camera shutter speed is probably the easiest path to achieving higher resolution.
joshua.vader wrote 02/23/2020 at 04:58 • point
Have you heard about the CHDK project? Perhaps your Powershot is supported: https://chdk.fandom.com/wiki/CHDK
joshua.vader wrote 02/23/2020 at 01:47 • point
How fast can you get each scan line?
joshua.vader wrote 02/23/2020 at 01:55 • point
ohhh ... so you are moving the entire vertical string of 144 LED's along the horizontal axis?  I was thinking that the strip was inside and used mirrors on the stepper drive or something to direct the light
John Opsahl wrote 02/23/2020 at 02:30 • point
Yup, 72 LEDs actually. The image is 72x72. It takes a little over 15 seconds to flash the entire image. Any faster and the LED strip starts to oscillate too much. Longest shutter speed on most smart phones is 10 seconds so you get about 75% of the image. The shutter speed on my cannon powershot camera goes up to 15 seconds so it is what I have been using to capture the images.
