Does it have to be pretty?
A project log for Breadboarded 3-Axis Sine-Cosine Controller
Build this controller to engrave the PCB for your permanent controller
darrin-bDarrin B • 02/17/2020 at 19:52•0 Comments
Just posted the KiCAD schematic set. Oops, forgot to annotate a whole bunch of parts. I'll fix that. But, that is the circuit that is on my desk, spinning motors right now. The exception being R_Start1, it wasn't necessary for my oscillator to reliably start.
If the parallel port isn't for you, the interface signals are fairly simple.
NameIn/OutUsage
DirectionInSelects either cosine or inverted cosine to control stepper direction.
Run/Stop
X/Y/Z
InSwitches the sine and the selected cosine signal on or off.
WINOutThis signal goes high each time the sine or cosine does a zero-crossing. It also clocks the flip-flops, so that signals switch at the end of a full step. Switch a motor on, count WIN pulses to track the number of steps a motor takes.
Polarity
Pol0/Pol1
OutThese two signals indicate the state of the oscillator, and state of a motor's rotor when it is running. Coordinating the motor's state with these signals will allow for smooth starting and direction changes.
