Now with onboard USB for Arduino Programming and diagnostics. 30A @ 30V (~1kW)
- Made for JLCPCB SMT assembly (minus WROOM, Tact switches and connectors)
- switched to mostly 0402 components to save space
- Can fit either the ESP32-WROOM-32U (U.FL antenna Connector) and 32D (PCB antenna)
- CAN connectors on the same side
- Better/centre location for MOSFET temp sensor
- Two 2.54 top mount connectors for Servos, FANs or limit switches (2 IO pins)
- Fixed power supply switch over (Can be powered and programmed via USB)
- Fixed missing test to 0V connection on MA730/MA702 encoder
- Added Pull down for IO12
- Added Tactile Switches for Boot and RST/Enable
