I wanted to show you some basic field Monster position detection, for it I built a simple prototype using IR sensors. The code for detection can be found named "MonsterZoneDetection_IR". As you can see a transparent sheet serves as a place for the card to lay down and since IR light passes through this sheet it does not get detected as a card. When a card is placed on top of a sensor it gets triggered and outputs a digital high signal.
![](http://cdn.hackaday.io/images/5646501585777158150.jpg)
![](http://cdn.hackaday.io/images/1350351585777208431.jpg)
![](http://cdn.hackaday.io/images/4607371585777257144.jpg)
![](http://cdn.hackaday.io/images/8609421585777304588.jpg)
![](http://cdn.hackaday.io/images/9090601585777340606.jpg)
![](http://cdn.hackaday.io/images/3800221585777369291.jpg)
