8-way isolated input, high reliability and stability.
8-way isolated output, contact max load 5A@220V AC.
RS485 communication port, supports BACnet MS/TP
Power supply: DC 24V
Dimension: 154mm 105mm 50mm
Why we made it?
In many industrial area, we need to monitor and remote start or off field machines. So we designed this product
Applications area
Lighting Control Systems
Pump Control
Valve Actuation
Grain Augers
Engine Control
Tank Level Monitoring
PLC, DSC, DAC
SCADA
If you are interested can contact me via email daovanhoa12@gmail.com
Ai-Thinker
bobnet
Saabman
Ah, looks like the Velleman K8000 board, which I developed code for in MSDOS back in the day. Main difference being that you needed the PC to control that one, no MCU onboard at all.
