BACnet MSTP, 8DI 8DO
Expansion Module BACnet MSTP, 8DI 8DO
Module BACnet MSTP, Expansion IO, 8DI 8DO
8-way isolated input, high reliability and stability.
8-way isolated output, contact max load 5A@220V AC.
RS485 communication port, supports BACnet MS/TP
Power supply: DC 24V
Dimension: 154mm 105mm 50mm
Why we made it?
In many industrial area, we need to monitor and remote start or off field machines. So we designed this product
Applications area
Lighting Control Systems
Pump Control 
Valve Actuation 
Grain Augers
Engine Control
Tank Level Monitoring
PLC, DSC, DAC
SCADA
If you are interested can contact me via email daovanhoa12@gmail.com
Module mở rộng 8DI 8DO BACnet MSTP.mp4
MPEG-4 Video - 13.78 MB - 02/17/2020 at 07:44
Download
JPEG Image - 1.29 MB - 02/17/2020 at 07:42
Preview
JPEG Image - 2.97 MB - 02/17/2020 at 07:41
Preview
  • 1 × ATmega2560 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 2 × LM2596 Power Management ICs / Switching Regulators and Controllers
  • 8 × Relay Power Supplies / Uninterruptible Power Supplies (UPS)
  • 8 × OPTO PC817
View project log
