ESP32-CAM Video Surveillance Robot
Build your own video surveillance robot and control it through the Internet with iPhone
Imagine if you have a robot that has camera on board and can be controlled through Internet.
It would open a lot of opportunities of using it.
For example you could send the robot to the kitchen to check if you accidentally left the kettle on the stove!
I found that with ESP32-CAM it can be done easily.
JPEG Image - 11.77 MB - 02/15/2020 at 23:03
Preview
JPEG Image - 6.05 MB - 02/15/2020 at 23:03
Preview
JPEG Image - 7.31 MB - 02/15/2020 at 23:03
Preview
JPEG Image - 6.93 MB - 02/15/2020 at 23:03
Preview
JPEG Image - 7.67 MB - 02/15/2020 at 23:03
Preview
View all 19 files
  • 1 × ESP32-CAM
  • 1 × FT232RL FTDI Mini USB
  • 1 × Dual Channel DC Motor Driver L298N
  • 1 × Adafruit (PID 3244) Mini Round Robot Chassis Kit - 2WD with DC Motors
  • 1 × 18650 Battery Holder
View all 9 components
  • 1
    Step 1
    Parts List
    Parts List:
    ESP32-CAM x1
    FT232RL FTDI Mini USB x1 - for uploading a code to the ESP32-CAM
    Dual Channel DC Motor Driver L298N x1
    Adafruit (PID 3244) Mini Round Robot Chassis Kit - 2WD with DC Motors x1 - I used this chassis, but you can make your own or buy any other available chassis. What we need here is wheels and DC Motors
    18650 Battery Holder x1
    18650 Battery x2 (as an alternative four AA batteries and its holder can be used instead of 18650 batteries)
    Mini Pan/Tilt Platform w/ 2 SG-90 Servos x1
    MB102 Breadboard Power Supply Module x1
    iRobbie-A iOS App
  • 2
    Assemble the Chassis
    Assemble the robot chassis with two DC motors, 3 wheels and mini L298N motor drive controller. Use use a mounting tape to attach the motor drive controller to the platform.
  • 3
    Connect Wires
    Connect wires as shown on the schematic.
View all 10 instructions
Edward wrote 09/19/2020 at 20:29 point
Well-done project I have to admit. But I have a question: could I use this camera for biometrical identification with https://recfaces.com/ applocation or not? I think it should be an interesting security system.
