Hackaday.io Hackaday.io
Sign up Log in
Neopixel Bike-Light System
Signaling and light system for bicycles in order to communicate with surrounding vehicles
augustoAugusto
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
6 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
734
0
6
8
Team (1)
  • augustoAugusto
Join this project's team
hardware
ongoing project
neopixels arduino adafruit bike biking LEDS
This project was created on 02/21/2020 and last updated 6 years ago.
Description
The bike system is composed by two rear lights composed of 1x8 Neopixel strips and one front light of only one strip. The system is powered by a smartphone power-bank and controlled by an Arduino. The different indications are generated by the user via a D-Pad like controller positioned in the bike's handles.
Components
  • 1 × Arduino Pro Micro
  • 1 × 5x5 PCB one sided
  • 2 × 1x12 Pins
  • 3 × Neopixel Strips 1x8
Project Logs
Collapse
  • Test of Basic Signals
    Augusto • 02/21/2020 at 16:24 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
OR
The 2015 Hackaday Prize
Dark-activated, 2.8 candela white LED with wide 160-degree light output powered by a 9 V battery.
Project Owner Contributor
BlackOut Light
kris-winerKris Winer
A minimalist grow light that is compatible with the Adafruit Feather Huzzah dev board.
Grow Light Feather Wing
alexandra-covorAlexandra Covor
I always forget to turn off the light, no longer bother to turn the lights
Arduino controlled door trigger light bulb
erkinerkin
The 2017 Hackaday Prize
Don't you hate when people start honking a split-second after the light turns green? Sometimes this is justified and other times simply not.
Green Traffic Light Reminder (anti-honking)
traxtrax
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Neopixel Bike-Light System", please tell us the reason.
Send message
Remove Member
