You can read more about this and other Esmacat tutorials on the official Esmacat website. You can also learn more about us on our main website.
Detailed documentation of the codes and steps for this tutorial can be found here.
Check out our EASE Crowd Supply Campaign Page: https://www.crowdsupply.com/harmonic-bionics/ease
Overview:
In this tutorial, you will learn how to set up and use the EtherCAT Arduino Shield by Esmacat (EASE) Slave device on top of an Arduino subsystem and interface it with a Touch LCD and Motor Shield to enable data transfer between the two slave devices via the EtherCAT master (Laptop/PC).
- First, some general information about the shields is discussed.
- After learning to set up the devices, you will learn to implement a practical project involving both the Touch LCD and Motor Shields to control the Motors connected via the buttons on the LCD Shield by exchanging data between the 2 slave devices and the EtherCAT master. The data about the current motor to be controlled and its state (speed/position) is also printed on the terminal of the master.
EtherCAT Arduino Shield by Esmacat (EASE):
EASE is an EtherCAT slave that connects to an EtherCAT master (PC/ Laptop/ Dedicated Master devices like the Esmacat Master S and Esmacat Master C.) It can be stacked on top of Arduino and other MCU boards capable of connecting a shield with an Arduino Uno form factor. This shield allows high-speed communication with an industry-standard EtherCAT protocol for high-performance robotic applications.
This shield has 8 registers that can be used to send/receive data between devices via Ethernet cables attached to the shield.
More info: https://www.esmacat.com/ease
Suggested Reading: EASE Datasheet.
Touch LCD Shield:
Display screens can be of very simple types such as 7 Segment or character LCDs or more advanced models like OLEDs and TFT LCDs. 2.4” TFT (Thin film Transistor) shield is one of the most widely used graphic screens with "Touch" input. Here are its most important features:- 240*320 pixels resolution
- Ability to display 262000 different colors
- Includes a touchpad
- 5v supply voltage
Motor Shield:
The Adafruit Motor Shield is a stackable motor shield that allows up to a maximum of 2 Servo motors, 4 DC motors or 2 Stepper Motors to be controlled using a single shield. By configuring the shield for our requirement one can control the motors as per the need. In this tutorial 1 servo motor, 1 dc motor and 1 stepper motor has been controlled as a proof of concept.Hardware Connections:
The primary hardware components include,- EtherCAT slave1 (EASE with Arduino)
- EtherCAT slave2 (EASE with Arduino)
- EtherCAT Master (PC/Laptop)
- Power Over Ethernet (POE Injector)
- Motor Shield
- Touch LCD Shield
- Motors
- Ethernet cables
- DC Adapter (for POE) and
- Power Source (battery to power the motors)
Required Libraries:
There are two libraries that will be used for this tutorial.- An EASE Library for Arduino to communicate with the Arduino subsystem.
- An Esmacat Master Library for the master (PC) to communicate with the EASE slave device.
Software :
The software required for this tutorial involves coding for- the Esmacat Master and
- the Arduino.
Running the Master Code:
On running the master code you get a result similar to the following on the Master terminal (the result attached below is an example result on execution on a Windows PC) with the motor selected and the desired position/speed change.
Esmacat
