Here's my initial specs although it might change:
- SSB voice and data, probably CW.
- Headphone/line out as well as a built-in speaker
- Mic in (probably an electret only) and line in/PTT line for sound card use
- Basic built-in CW "straight key" for basic morse and transmission for tuning
- Support for an external keyer
- Superhet, most likely single conversion but if image rejection is a problem I'll add another IF
- QRP level output (5W) and the capability to feed an external amp with pre-PA power (such as this)
- Basic controls on a simple LED/LCD display with tuner, power level, CW configuration, some memories, etc.)
- AGC and S-Meter
- Ideally a tunable IF filter, or at least a couple of different options
