Now that the toolchain works, it is possible to write a program, assemble the program, enter the program in RAM, and then run the program.
The Assembler
The a68 Assembler is here. The MIKBUG debugger source file is here.
Typing in a short program
Typing in a program is time consuming, There are standard entry points for the debugger I/O which can be called. The list file for the debugger is here.
A simple program example is to read a character from the PS/2 keyboard and then write it out to the Video Display Unit (VDU).
The function to input a character from the PS/2 keyboard is:
; INPUT ONE CHAR INTO A-REGISTER
c1f3 8d fa INEEE BSR SAV
c1f5 b6 80 18 IN1 LDAA ACIACS
c1f8 47 ASRA
c1f9 24 fa BCC IN1 ;RECEIVE NOT READY
c1fb b6 80 19 LDAA ACIADA ;INPUT CHARACTER
c1fe 84 7f ANDA #$7F ;RESET PARITY BIT
c200 81 7f CMPA #$7F
c202 27 f1 BEQ IN1 ;IF RUBOUT, GET NEXT CHAR
c204 7d 7f 0d TST ECHO
c207 2f 01 BLE OUTEEE
c209 39 RTS
The function to output a character to the VDU is:
; OUTPUT ONE CHAR
c20a 36 OUTEEE PSH A
c20b b6 80 18 OUTEEE1 LDA A ACIACS
c20e 47 ASR A
c20f 47 ASR A
c210 24 f9 BCC OUTEEE1
c212 32 PUL A
c213 b7 80 19 STA A ACIADA
c216 39 RTS
It should be easy to write the code to read a character and then echo it out. Here is the instruction set card for the 6800. The In/out functions are written as subroutines can get called with a JSR. The instruction to jump to a subroutine is:
The instruction to branch back to start is:
; INEEE EQU $C1F4
; OUTEEE EQU $C20A
LOOP4VR
JSR $C1F4
JSR $C20A
BRA LOOP4VR
The listing file is:
0000 LOOP4VR 0000 bd c1 f4 JSR $C1F4 0003 bd c2 0a JSR $C20A 0006 20 f8 BRA LOOP4VR
Commands to enter, disassemble and run program:
; E CHANGE MEMORY ; D DISASSEMBLE CODE ; G GO TO PROGRAM
Runs but prints a lot of chars...
land-boards.com
