Did a build for the RETRO-EP4CE15 card. The build uses the 1MB of external SRAM as 64 banks of 16KB each. The banks are in the CPU address range of 0xC000-0xDFFF. There is a bank control register which initializes to bank=0 at power up or reset.
The 6800 CPU has a total of 60KB SRAM 9addressable. The rest of the RAM is internal to the EP4CE15 FPGA. The CPU memory map is:
-- Memory Map -- x0000-x7fff - 32KB Internal SRAM -- x8000-xbfff - 16Kb SRAM bank (64 banks) -- xc000-xefff - 12KB Internal SRAM -- xf000-xffff - 4 KB ROM (minus I/O space) -- xfc00-xfcff - I/O space -- xfc18-xfc19 - VDU/UART (6850 Interface) -- xfc28-xfc29 - UART.VDU (6850 Interface) -- xfc30 - Bank Select register (r/w)
The 12KB of SRAM could be initialized at boot and could function as a ROM space for an O/S, etc.
