Put together a minimal build which runs in the EP2C5 FPGA. It does not use any external SRAM. The features are:
-- MC6800 CPU -- Running MIKBUG from back in the day (SmithBug ACIA version) -- 25 MHz -- 4K (internal) RAM version -- MC6850 ACIA UART -- VDU -- XGA 80x25 ANSI character display -- PS/2 keyboard -- SD Card -- Not used -- Included in pin list with inactive levels (in case a card is installed) -- -- The Memory Map is: -- $0000-$0DFF - 3.5KB SRAM (internal RAM in the EPCE15) -- $7E00-$7FFF - 512B SRAM (internal RAM in the EPCE15) -- $7F00-$7FFF are used as scratchpad RAM by MIKBUG -- $7E00-$7EFF can be used by application program -- $8018-$8019 - VDU -- $8028-$8029 - ACIA -- i_SerSelect (Pin_60 of the FPGA) swaps addresses of VDU and ACIA port (requires pullup in FPGA) -- Installed (Pin_60 to Ground) uses Serial port -- $C000-$FFFF - MIKBUG ROM (repeats 4 times from $C000-$FFFF)
It works. It's a good baseline for starting a larger build.
land-boards.com
