Notes on SmithBug at 0xF000
- SmithBug is a variant of MIKBUG
- Updated by Herb Johnson to add S Record loader
- 60KB SRAM variant
- Supports much smaller SRAM sizes but requires scratchpad SRAM if ther is less than 60KB of SRAM
- Scratchpad RAM has to be at 0xEF00-0xEFFF (minimum 256 bytes)
SmithBug Memory Map
- 0x0000-0x7FFF - 32KB Internal SRAM
- 0XEC00-0xEFFF - 1KB Internal SRAM (SCRATCHPAD SRAM USED BY MIKBUG)
- 0xFC18-0xFC19 - VDU (serSelect J3 JUMPER REMOVED)
- 0xFC28-0xFC19 - ACIA (serSelect J3 JUMPER installed)
- 0xFC30-0xFC3F - Front Panel
- 0xF000-0xFFFF - MIKBUG (Actually SMITHBUG) ROM
Hardware
- Tested/runs on all MultiComp based designs
- SRAM accesses run at 25 MHz on Internal SRAM
- Different FPGAs can support more of less internal SRAM
- EP2C5 FPGA supports 3KB internal SRAM
- EP4CE15 FPGA supports 32KB internal SRAM
- Cyclone V FPGA supports 60KB internal SRAM
- External SRAM works on all MultiComp based designs and supports 60KB SRAM
- SRAM accesses run at 16.6 MHz on External SRAM
Commands
Build Instructions
- Creates .hex file load load in Quartus II
..\a68 DGG_MIKBUG.ASM -l DGG_MIKBUG.LST -s DGG_MIKBUG.s ..\srec_cat DGG_MIKBUG.s -offset - -minimum-addr DGG_MIKBUG.s -o DGG_MIKBUG.hex -Intel
