The RETRO-EP4CE15 card has 1MB of SRAM on the card. The SRAM is in (2) 8KB windows with 64 banks in each window.
I wrote a test routine that writes ramp values to the SRAM and verifies it works.
The test program prints:
S0++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 1+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++D
Where:
- S = start
- 0/1 = block number
- + = block good
- X = bad
- D = done
Hit a key at end to avoid resetting the Serial port until done.
Jumps back to SmithBUG when done.
Takes ~2 secs to run with 25MHz ROM/Internal SRAM and 16.7 MHz for External SRAM.
Assembled using A68 assembler
"..\..\A68 6800 Assembler\a68.exe" XRAMTEST.ASM -l XRAMTEST.LST -s XRAMTEST.SRE
Memory Map
- 0xA000-0xBFFF - 512KB External SRAM
- 8KB Windows, 64 frames
- MMU0 provides additional address bit
- MMU0 initialized to 0
- 0xC000-0xDFFF - 512KB External SRAM
- 8KB Window, 64 frames
- MMU2 provides additional address bits
- MMU2 initialized to 0
- 0xFC30 - MMU0 Latch 6-bits
- 0xFC31 - MMU1 Latch 6-bits
