Meshtastic is a project that lets you use inexpensive ($30 ish) GPS radios as an extensible, super long battery life mesh GPS communicator. These radios are great for hiking, skiing, paragliding - essentially any hobby where you don't have reliable internet access. Each member of your private mesh can always see the location and distance of all other members and any text messages sent to your group chat.
The radios automatically create a mesh to forward packets as needed, so everyone in the group can receive messages from even the furthest member. The radios will optionally work with your phone, but no phone is required.
It is fairly easy to port to other boards, but currently it works with the TTGO T-Beam and the Heltec Lora 32 boards. You can develop or use this software without any soldering. We'd love you to try it and join our effort!
Uses
- Outdoor sports where cellular coverage is limited. (Hiking, Skiing, Boating, Paragliding, Gliders etc..)
- Applications where closed source GPS communicators just won't cut it (it is easy to add features for glider pilots etc...
- Secure long-range communication within groups without depending on cellular providers.
- Finding your lost kids ;-)
Features
Not all of these features are fully implemented yet - see below. But they should be in by the time we decide to call this project beta (three months?)
- Very long battery life (should be about eight days with the beta software)
- Built in GPS and LoRa radio, but we manage the radio automatically for you
- Long range - a few miles per node but each node will forward packets as needed
- Shows direction and distance to all members of your channel
- Directed or broadcast text messages for channel members
- Open and extensible codebase supporting multiple hardware vendors - no lock in to one vendor
- Communication API for bluetooth devices (such as our Android app) to use the mesh. So if you have some application that needs long range low power networking, this might work for you.
- Eventually (within a couple of months) we should have a modified version of Signal that works with this project.
- Very easy sharing of private secured channels. Just share a special link or QR code with other users and they can join your encrypted mesh
Leo Febey
Keegan
matt oppenheim
Les Hall
Has anyone ever proven meshtastic to forward packets? All the videos on YT only show point to point. I had 3 devices that could see each other when they all had each other in LOS, but when mesh functionality was required to reach the last node no packets went through.
