Updated the firmware to make trackball detection similar to the 5200 softare:
- Voltage at pin 9 is dropped and signal is sampled by two consecutive frames.
- Voltage at pin 9 rises again and signal is sampled 4 more times.
![Yellow: X axis, Blue: Pin 9 Voltage Yellow: X axis, Blue: Pin 9 Voltage](https://cdn.hackaday.io/images/8198481616299595282.png)
A project log for Atari 5200 Controller Port Emulator
Develop joystick adapters for Atari 5200 without having the console
