This Cisco 8-port model is basically NO different then the cheaper Netgear GS208, it uses the same exact RealTek Ethernet chip, and same type of switching buck power supplies on the board.
So there is really NO reason to spend the extra money for the 'CISCO' module, unless you want the metal hard shell, which this cisco unit does have. The Netgear GS208 is all plastic, hence it's cheaper to manufacture, but under the hood both units will perform exactly the same.
