I started making the patch cables.
I found some relatively inexpensive 2 mm banana plugs at about 56 cents CDN each. The wire is silicon based and very flexible. From Amazon:
- 22 Gauge Electric Wire,Tinned Copper Wire Kit 22 AWG Flexible Silicone Wire(6 Different Colored 26 Feet spools) 600V Electronic Hook up Wire
- 20PCS Gold Plated Banana Plug for Speaker Wire, Home Theater, Wall Plates and More(Five Colors Choices)
The cables are colored coded by length and are based to the original H-500 except black was substituted for brown and there are no orange cables. Here is what the original cables looked like (from http://www.so-much-stuff.com/pdp8/computerlab/computerlab.php):
And here are the plugs that were used. If anyone knows what this type of plug is called and where one might find a supply I would be eternally grateful.
As I stated before the 2 mm banana plugs I'm using work great with the rivets so I'm fine with them for now.
Starting with 50 cables.
Michael Gardi
