- Replace fuse footprint with two holes so an external fuse holder can be installed instead of automotive fuse
- Apply patch and fix from SE (board ID: Reinhardt) so any size of resistor can be used
- Add LC edition (board ID: Finlandia) for reduced component count (few components have been swapped out with combined component for ease of soldering)
- Reduce board size for LC edition
Torbjörn Lindholm
