The circuit needs to be very robust. Kids can plug in any small DC motors
I've built this circuit before using a motor driver and an Arduino. However, it's over kill for young creators . So I want to combine a bluetooth with a driver in one board (see pictures).
Whats the best bluetooth module to use?
And which driver chip should I use?
Input
- Voltage range should be 3 to 9 volts
- Speaker Push Terminals. Color coded
Output 1, 2
- 3-6 volt output Push terminals. max 800 mA
Output 3
- led 3 volt max 30mA connection indicator
basic Polarity safety electrical on both ends. Any suggestions
power indicator
Built in Bluetooth antenna.
I found this one, https://www.robotshop.com/ca/en/motorair-bluetooth-dual-motor-driver-smartphone-remote-control-kit.html
Like that but simpler, cheaper, more robust. Only has bluetooth.
