After further testing, I can confirm that 2 motor drivers and all 4 motors work! See the video below to see all 4 motors vibrating sequentially.
Below is the code that I wrote to sequentially test all 4 motors:
import time
import machine
from machine import Pin
motor1 = machine.PWM(Pin(18))
motor2 = machine.PWM(Pin(19))
motor3 = machine.PWM(Pin(22))
motor4 = machine.PWM(Pin(23))
motor1.freq(1000)
motor2.freq(1000)
motor3.freq(1000)
motor4.freq(1000)
while True:
motor1.duty(341) # Motor 1 on
time.sleep(2)
motor1.duty(0) # Motor 1 off
time.sleep(2)
motor2.duty(341) # Motor 2 on
time.sleep(2)
motor2.duty(0) # Motor 2 off
time.sleep(2)
motor3.duty(341) # Motor 3 on
time.sleep(2)
motor3.duty(0) # Motor 3 off
time.sleep(2)
motor4.duty(341) # Motor 4 on
time.sleep(2)
motor4.duty(0) # Motor 4 off
time.sleep(2)
Now that I verified all 4 motors working, my next test will be sending messages via MQTT to the ESP32 to activate motors, simulating notifying the user of a deviation from the drawing path.
