Hackaday.io Hackaday.io
Sign up Log in
G[-Code]oy-Stick
Upcycled GamePort Joystick. Arduino Nano based Bluetooth communication sending G-Code to a 3d-printer.
jj
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
3 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 2
View Gallery
286
2
3
6
Team (1)
  • jj
Join this project's team
  • Demo
MISC
ongoing project
laser gcode bluetooth
This project was created on 03/12/2020 and last updated 5 years ago.
Description
This old GamePort Joystick came back to life including a big light show.
With it you can manipulate the position of a focused laserbeam including the operation status of the laser itself. While sending several G-Codes for movement (xyz), fan-spin (on/off), and activation of the relative movement mode of the 3d-printer (for reasons) its a nice toy to use a strong (500mW) and focused laser safely. "Why would you need the z-axis ?" one might ask. it's a "nice to have" when placing objects different heights
I'm plaing to include a sd-card slot so a gcode.txt could be read and transmitted to the printer line by line. Until then there is a several g-code hardcoded onto the nano, witch can be send by switching the turbo-button on and off again.
The old 3d-printer is a project itself. I might post it soon.
here it is: https://hackaday.io/project/171275-robo-laser-2d
Details
Log In/Sign up to comment
Sign up with Github
OR
Tom Nardi wrote 08/27/2021 at 05:59 • point
Is that a transparent version of the joystick they based the mines in Goldeneye on?
j wrote 08/27/2021 at 07:28 • point
That joystick was a 1990ies gameport device. I just looked it up and it looks exactly like that !
A plotter wich is made from laser cutted acrylic, and designed as an inject printer
Project Owner Contributor
Laser cutted Plotter
morten-ydefeldtMorten Ydefeldt
Learn how to convert your 3D printer to a 2D plotter. We'll cover 3D models and G-code in Python.
3D Printer to 2D Plotter with Custom G-code
travis-bumgarnerTravis Bumgarner
Transformed an old IdeaWerk 3D printer into a laser engraver by modifying its hardware and firmware for cost-effective DIY engraving.
Hacking Old IdeaWerk 3DPrinter Into Laser Engraver
iqra-rehmanIqra Rehman
RayvenOne is a SLS 3D printer for the desktop.
RayvenOne
mx3designsmx3designs
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "G[-Code]oy-Stick", please tell us the reason.
Send message
Remove Member
