Genesis support is finally done!!! I also added support for parallel interfaces for systems like NeoGeo, Supergun, JAMMA, Atari 2600, Master System, etc.
Hotfixes
* [PS3] Fix again PS3 timing for earlier controller version
* [BLECFG] Add minimal support for Find By Type Value Request
Bluetooth
* Add basic PS5 Dual Sense support via PS4 HID mode
Wired
* Add Genesis 3 buttons support (2 players)
* Add Genesis 6 buttons support (2 players)
* Add SEGA's Team Player multitap support (8 players)
* Add EA 4 Way Play multitap support (4 players)
* Add 1P 12 buttons parallel mode (NeoGeo, JAMMA, etc)
* Add 2P 6 buttons parallel mode (Atari 2600, Master System, etc)
* Add 1P 6 buttons parallel mode while in auto mode while waiting for detection
Consult the following documentation for building cables:
- Parallel 1P (12 buttons) adapter cable
- Parallel 2P (6 buttons each) adapter cable
- Genesis adapter cable
Consult the following documentation each system usage & web-config specifics:
