Global
- [MGR] Add support for internal install for all system (Only tested GC)
- [GAMEID] Add support for Game ID for PS1, N64 & GC multi config selection
- [ADAPTER] Reduce 8bit accessible heap memory usage (Fix memcard malloc in universal build)
Wired
- [GC] Support all command format
Bluetooth
- [BT] Add support for 8bitdo M30 controller
- [BT] Add RetroFighters GC adapter support
- [ADAPTER] Fixup 8bitdo Gbros B & X mapping
Firmware is now available in 2 different flavor
1. Regular FW as before retroactively renamed HW1 (Typically for external adapter)
Use firmwares from HW1 archive for:- WillConsole's PSUnoRetro
- All Humble Bazooka's BT dongle
- RetroTime's N64 dongle
- RetroOnyx's VB dongle
- GrechTech's RetroRosetta
- any DIY adapter you made base on the original BlueRetro spec
- most likely anything from aliexpress
2. HW2 FW that support power management and port detection (Typically for internal install)
Use firmwares from HW2 archive for:
- Laser Bear Industries's GameCube BlueRetro Internal Adapter
- any DIY internal install you made base on the HW2 spec
