WOOF Model Rocket Launchpad Computer V4
Easy to use Arduino Uno Shield to support your rockets from the ground!
Public Chat
WOOF is an open source Arduino Uno shield designed to control you rocket launches! It has all the outputs and interaction units you need! A buzzer and super bright RGB led to give you both auditory and visual warnings, 8 servo launch clamp outputs, 6 individual servo outputs, and 2 mosfet igniter outputs! The system uses common components to keep the cost down. Designed for beginners to build on the CRT PCB line
More details coming soon!
Gerber_WOOF! Launch computer_20200313141420 (1).zip
The Gerber File
x-zip-compressed - 175.19 kB - 03/13/2020 at 18:47
Download
  • 1 × WOOF Pcb Board
  • 7 × 100 Ohm Resitor
  • 1 × MHP5050RGBDT (SMD RGB LED)
  • 6 × DB125-3.81-2P-BK-S (Through Hole Terminal Block)
  • 1 × TMB12A05 (5 Volt Buzzer)
View all 7 components
View all 3 project logs
  • 1
    Step 1
View all instructions
samkortland wrote 07/01/2020 at 10:42 • point
Never mind I found out how to do it, but how do I get the Gerber files into EasyEDA or any other PCB manufacturer?
samkortland wrote 07/01/2020 at 09:31 • point
Hi, Any chance you could tell me how I could get my hands on a WOOF Pcb Board, or any pcb board for that matter that I could use for this?
Canine Defense Technologi wrote 07/28/2020 at 04:32 • point
Hello, This is a computer designed to control ground operations of a model rocket launch
