I have half a dozen things already in the queue, but in my next PCB run I am thinking of adding a single 2764 EPROM version of the SBC-85 SBC. This would avoid the 21V 2732A EPROMs while not changing the overall memory space of the SBC-85.
Any thoughts or suggestions?
good suggestion. Thanks
If you wire up pins 26 and 27 to GND and VCC respectively, the slot can also accommodate 27128 and 27256 chips for those who already have them. The image would be put in the first half and the third quarter respectively of those EPROMs.
