Here we are intending to show how to control the speed of an AC Induction motor with Squirrel cage design using SOLO. You will see how this operation is done in a sensor-less mode in a Vector control manner (FOC), firstly with only two potentiometers and then using SOLO Motion Terminal using the USB.
