The arm prints and the corresponding paddles/pivots did not turn out perfectly, but they will still work regardless and I suppose that is part of the point.
![](https://cdn.hackaday.io/images/553341603482444809.jpg)
I decided to use the post out of a rivet I had here as my retaining pin.
![](https://cdn.hackaday.io/images/2907691603482474829.jpg)
![](https://cdn.hackaday.io/images/4549661603482502091.jpg)
A project log for COSV - Cam Open Source Ventilator
Roller cam based portable BVM ventilator.
