Wiring up the AM2901 to the Arduino Mega and getting a responce. To start out I have only wired access to 2 of the address lines for the registers. The output port from the AM2901B was held enabled.
Wiring
Mega | AM2901 |
2,3 4,5 6 7 | A0,A1 B0,B1 Clock Carry in |
14,15,16,17 | Data Out (Y) |
30,31,32 | ALU Source |
33,34,35 | ALU Function |
36,37,38 | ALU Desitnation |
50,51,52,53 | Data In (F) |
RAM0 to RAM3 | |
Q 0 to Q 3 | |
Held High | A2, A3 B2, B3 |
Held Low | F output enable. |
Bit order for ports do not follow pin order
