Spent some time writting micro op setup for testing chips. I went through my personal collection of chips and they all passed.
Code
clear_regs(0); Serial.println(" Reqister Q"); // check q register Micro_Op(DO, 0, REGQ, 0, 0, 0, 1); // Set Q Micro_Op(OQ, 0, RAMQU, 0, 0, 0, 0); // Shift Q up Micro_Op(OQ, 0, RAMQU, 0, 0, 0, 0); // Shift Q up Micro_Op(OQ, 0, RAMQU, 0, 0, 0, 0); // Shift Q up Micro_Op(OQ, 0, RAMQU, 0, 0, 0, 0); // Shift Q up Micro_Op(OQ, 0, RAMQD, 0, 0, 0, 0); // Shift Q Down Micro_Op(OQ, 0, RAMQD, 0, 0, 0, 0); // Shift Q Down Micro_Op(OQ, 0, RAMQD, 0, 0, 0, 0); // Shift Q Down Micro_Op(OQ, 0, RAMQD, 0, 0, 0, 0); // Shift Q Down Micro_Op(DO, 0, REGQ, 0, 0, 0, 15); // Set Q Micro_Op(DO, 0, REGQ, 0, 0, 0, 10); // Set Q Micro_Op(DO, 0, REGQ, 0, 0, 0, 5); // Set Q Micro_Op(DO, 0, REGQ, 0, 0, 0, 0); // Set Q // check ram for (int i = 0; i <= 3; i++) { Serial.println(" "); Serial.print(" Ram "); Serial.println(i, HEX); Micro_Op(DO, 0, RAM, i, i, 0, 1); // Set Reg[0] Micro_Op(OA, 0, RAMQU, i, i, 0, 0); // Shift Ram up Micro_Op(OA, 0, RAMQU, i, i, 0, 0); // Shift Ram up Micro_Op(OA, 0, RAMQU, i, i, 0, 0); // Shift Ram up Micro_Op(OA, 0, RAMQU, i, i, 0, 0); // Shift Ram up Micro_Op(OA, 0, RAMQD, i, i, 0, 0); // Shift Ram Down Micro_Op(OA, 0, RAMQD, i, i, 0, 0); // Shift Ram Down Micro_Op(OA, 0, RAMQD, i, i, 0, 0); // Shift Ram Down Micro_Op(OA, 0, RAMQD, i, i, 0, 0); // Shift Ram Down Micro_Op(DO, 0, RAM, i, i, 0, 15); // Set Reg[0] Micro_Op(DO, 0, RAM, i, i, 0, 10); // Set Reg[0] Micro_Op(DO, 0, RAM, i, i, 0, 5); // Set Reg[0] Micro_Op(DO, 0, RAM, i, i, 0, 0); // Set Reg[0] } for (int i = 0; i <= 3; i++) { Serial.println(" "); Serial.print(" Ram PortB "); Serial.println(i, HEX); Micro_Op(DO, 0, RAM, 0, i, 0, 15); // Set Reg[0] Micro_Op(OB, 0, RAM, 0, i, 0, 0); // Set Reg[0] Micro_Op(DO, 0, RAM, 0, i, 0, 10); // Set Reg[0] Micro_Op(OB, 0, RAM, 0, i, 0, 0); // Set Reg[0] Micro_Op(DO, 0, RAM, 0, i, 0, 5); // Set Reg[0] Micro_Op(OB, 0, RAM, 0, i, 0, 0); // Set Reg[0] Micro_Op(DO, 0, RAM, 0, i, 0, 0); // Set Reg[0] Micro_Op(OB, 0, RAM, 0, i, 0, 0); // Set Reg[0] }
