There are two errata I know about on this board
1. The XM line is pulled up. It's acutally an output. R2 can be omitted
2. (v0.2 only) E is placed on the system clock line not the clock as it should be (the CPU clock is the E clock in the motorola sense. Ben's 6522VIA card uses CLK and nothing yet uses the separate E clock so this causes no problems. If needed just wire CLK to pin2 of the jumper). The confusion is because the E pin on a 6502 has nothing to do with the motorola E clock.
It should also be possible to omit R4 as the RDY line has an internal pull-up
EtchedPixels
