After installing the new 74LVC8T245 level shifters into the circuit and reprogramming the FPGA to drive the DIR pin (which I've labeled A_B, because I can never remember which side of the bus is driving when it's high or low), I'm happy to report that the RC2014 booted fine.
I dropped into MBASIC from CP/M, and typed the following:
OUT 110,0:OUT 111,99 OUT 110,2:OUT 111,87 OUT 110,3:OUT 111,12 OUT 110,22:OUT 111,&h78
First line tells the VDC-II that there are 100 characters in a complete scanline. The second tells the VDC-II where the start of the HSYNC pulse resides on the scanline. The third sets the HSYNC pulse width. Finally, the fourth tells the VDC-II that there are 8 pixels per displayed character with no inter-character fill.
And I was immediate greeted with the following display on the oscilloscope:
![](https://cdn.hackaday.io/images/2500991587228067791.jpg)
This tells me several things all at once:
- You can interface to a Z80-compatible bus using 3-flop synchronizers clocked at 3.3x the Z80 bus frequency, without needing a dedicated bus clock input.
- TXS/TXB-type level shifters are not the correct type of level shifters to drive any kind of real bus, backplane or otherwise. They seem to be most useful for point-to-point circuits only; but, then, those are exactly the kind of links where not having a direction control is not a useful advantage to have. It's not clear to me what market TXS/TXB level shifters are intending to penetrate.
- 74LVC8T245 chips are powerful enough to drive a Mack truck, and fast enough to keep up with a Ferrari. Just make sure you set the DIR pin correctly.
- I really can solder SMT components without specialized equipment.
- nMigen rocks. TinyFPGA BX rocks. Based on my experiences with these tools, you can bet I'll try building more ambitious projects with this gear in the future.
