Arduino Ethernet Switch
It's an example of how to build with and arduino nano and a ethernet module, a switch that can be controlled via lan.
This is a project that was in my todo list for a long time, now with more time, i can spend a few hours building it.
The idea is really simple: a device that can allow me turn on/off another 12V device. Don't need the wifi, i want to do it via ethernet.
Configuration
Default IP address of the device is http://192.168.5.2 and will return a JSON string with the uptime and relays' status. There is no configuration process, just change the IP address for the one desired in the code.
Operation
URLAction
http://192.168.5.2/?status1=ONActivate Relay 1
http://192.168.5.2/?status1=OFFDeactivate Relay 1
http://192.168.5.2/?status2=ONActivate Relay 2
http://192.168.5.2/?status2=OFFDeactivate Relay 2
JSON
The JSON return has the following format:
'uptime':'1',   's1':'ON',   's2':'OFF'
uptime is in seconds. s1 and s2 can assume ON or OFF values, depend on the status of each relays.
  • 1 × Arduino Nano
  • 1 × Ethernet module enc28j60
  • 1 × DC to DC Step down
  • 1 × Relay Module You can use more than one if you want.
  • 2 × DC Jack barril or other type of connector if you want. I just wanted it to be easy to connect.
View all 6 components
View project log
  • 1
    Step 1
  • 2
    3d printed parts
    There are only two parts of the box, are really easy to print. The box originally designed to host two output jacks.
    You can download from thingiverse: https://www.thingiverse.com/thing:4246250
View all instructions
Rich text editor
Dan Maloney wrote 03/30/2020 at 16:52 point
Tricked me, too. This is better than a network switch, though - probably more useful.
dsl wrote 03/30/2020 at 06:44 point
[I cannot reply directly to your comment... that's weird]
Guille, of course I do! Personally, I support almost any DIY projects. Yours looks cool!
Tom Nardi wrote 03/28/2020 at 16:14 point
Definitely not the kind of "Ethernet switch" I was expecting, but very cool. Really like the idea of adding an uptime counter.
dsl wrote 03/29/2020 at 20:29 point
Yeah... I expected a 10BASE-T Ethernet L2 switch. Calling it a "latch" might be fair.
Guille wrote 03/29/2020 at 23:00 point
Hello. You are right, I chose the wrong name for the project, I just translated "Interruptor" into English. I hope that beyond that, you liked the project.
