Hey, I made a whistle.
A project log for VISP - Ventilator Inline Sensor Package
Bidirectional flow (volume), pressure, and temperature sensing in a single inexpensive I2C/SPI package.
masterofnullMasterOfNull 05/02/2020 at 02:122 Comments
The venturi restriction plus the short tube going to the sensor was just the right geometry for a good whistle.  That was annoying.
I added another pickup tube in the venturi, and connected them.  I am thinking this will cancel the waves where they meet.
As a last minute thought I made the geometry not symmetrical as well.  That might actually work against me now that I think about it.
Printing.
Edit: FFF version, the whistle was gone.  SLA version failed on first print due to low resin. It will be ready in the morning.
chris wrote 05/04/2020 at 17:09 point
Why not just make an in-line barrier plate with some small holes to provide flow restriction?  Then just take the pressure difference from the two sensors across the barrier.  P2 - P1 = f(k) * flow rate  even if k is not linear it should still be a simple curve at these low pressures and low velocities.
Seems like all these venturis and pitot tubes and so forth are harder than they need to be...
MasterOfNull wrote 05/04/2020 at 17:35 point
Yes.  Supposedly you lose less energy to the restriction this way.
