Snap on, snap off.
03/29/2020 at 09:26 • 0 commentsWorked on the 3D printed bits.
Ports now allow for two different sensors to be used. They have different footprints and so can't live on the same pads or even occupy any of the same space. I also added some clearance for a cover with a lip that will fit in alongside the PCB for a nice finish, and a bar along the top edge to capture our hookup wire.
I also added a snap-off support for the bottom pitot tube. That diameter determines the flow characteristics of the sensor exhale volume sensing so I wasn't willing to trust that a slicer would do the right thing and give me a clean edge there. The bottom tube is a lot strong than it needs to be so I can ensure the break happens at the right spot.
Cover is not done yet, but this new file is up.
https://github.com/Arcus-3d/cosv/blob/master/hardware/rendered/FFF/flow_sensor_for_pcb.stl
Sensor selection
03/29/2020 at 06:37 • 0 commentsWe would like to be able to support using either the BMP280 or the BMP388 for two of our sensors.
The two doing the differential sensing to detect the volume of the airflow, those are going to be BMP388's.
But for the other two, we may stick with the BMP280 just because they give us another datapoint: humidity.
So now the back and forth of now to work around the incompatible footprint between the two begins.
